Use UI's empty space click and drag to tweak values
mrlupin
Post by mrlupin »
it's a waste of space and time and focus to have to click on + or - then drag to change parameter values.
there could be an additional way to Quickly change values using the remaining space next to +/- buttons.
click and drag to the right to increase
click and frag to the left to decrease
or add sliders to the position & width
like a touch pad controller.
this could also benefit to touchscreens
it would be especially helpful and easier to move/scale elements.
Re: Use UI's empty space click and drag to tweak values
When you're working the shows that I work, those -/+ buttons are worth every penny of their value.
I think having a slider next to them or as an expanded UI option would be nice, but I wouldn't want to loose the -/+ buttons, ever!
mrlupin
Post by mrlupin »
I never wanted to remove them but have wiser and additional ways to move and scale elements. which is the weakest point of Resolume's UI and UX tbh
mrlupin wrote: Sun Nov 29, 2020 17:47 I never wanted to remove them but have wiser and additional ways to move and scale elements. which is the weakest point of Resolume's UI and UX tbh
Your phrasing of:
Made me believe you wanted to remove them. Just because you feel it's a "it's a waste of space and time" doesn't mean everyone does.
I'm all for adding a slider next to, or as a drop down function of these parameters. But I would NEVER call them a "waste of space and time" ;) ;)
