Jump to letter in side browser
I know you can search on top, but can we add functionality to when we select a fx, clip, or source, that when you press a letter (let's use "h" for an example in the fx window) that the highlighted target will jump to the first thing in the list with that letter (so hue rotate would pop up). If i use the search, i then have to clear it out (which i never do) and that ends up taking more time away from my next search :)
He2neg
Re: Jump to letter in side browser
Post by He2neg »
Yes please... somehow the effects need to be easyier to find and search.... its either a lot of scrooling or a lot of typing...
Collapse all also would be a part of the solution ;)
~Berlin~
vectorfuton
Post by vectorfuton »
I like this idea. Collapse all is a good add on too. Hell, if I could straight up remove certain FX from the list that I never use, would clean up the workflow even moreso!
