Beginner Questions part 2: Frame Rate conforming into FCP
smooshieface
Post by smooshieface »
Hi Guys,
I know this is probably a dumb question, however I have tried to figure it out through my own research.
I have two different VJ Loops the I converted in Alley to DXV 3.
I structure a composition with some generators and mix in the imported files, I note one file's frame rate is 29.97 and the other is 25.
Things run shoots.
I record the performance as pro res 422 and bring into Final Cut Pro in a new project a 25 fps (PAL)
Australia. I get stuttering video files.
I conform inside FCP to either frame blending, floor, etc... But its just not smooth≥
Question : Is it possible to assign an output frame rate of resolume for recordings?
Re: Beginner Questions part 2: Frame Rate conforming into FCP
Try changing your composition settings to the fps you desire and see if that does the trick :)
Do you see stuttering already playing back the prores recording in a standalone player?
Prores needs the most resources to be encoded, it can easily happen that the CPU can't keep up encoding, and some frames are dropped. You can spot this by enabling Show FPS in the Resolume output menu, and checking the value in the Preview monitor. The FPS will fall below your target if frames are dropped.
PhotoJpeg is the easiest to encode, maybe it's worth a try.
