Can you record audio directly into Resolume from Soundcard input? (not for FFT)
Karl KTS
Post by Karl KTS »
Hello! Is it possible to use the record audio when recording video from a webcam straight into Arena using the new record function? I would like to make drumming video loops straight into it but so far have only managed recording video. I can record audio with the video when recording a clip with audio (so yes I have audio also selected under recording settings already) But it just doesn't seem to work with inputs from my Focusrite Scarlett 2i4 soundcard or from the webcam's built-in mic so I suspect it's just not possible on Resolume? But I would like to make sure that's the case, as it's proving to be quite a pain to record in an external program and import in. Thanks! :D
Re: Can you record audio directly into Resolume from Soundcard input? (not for FFT)
Audio input recording isn't supported at this time. For that you might try a Spout output from Resolume into OBS and then use your DAC interface in OBS as well, that should keep your latency to 0.
You might move this to the features request section as I think this could be a handy feature in the future :)
Karl KTS
Post by Karl KTS »
Okay thanks for the response and advice Arvol! :)
jobee
Post by jobee »
Hey folks,
Is there any update about this subject?
Or would you have an advice about a capture card that could make the mix of a video stream coming from Resolume (in HDMI for exemple) with a sound capture made by a microphone?
Maybe is that a bad idea :-)?
Best regards
Jonathan
We have a ticket for this.
