Slide between multiple video clips
kurt_j_g
Post by kurt_j_g »
Hi all,
New to resolume and the forums. Hoping this isn't too stupid a question.
I have been able to bring in my NDI sources into Resolume, but now I want to scroll horizontally through the sources on loop forever.
I have found the Slide effect which is the effect that i'm after, i just need to work out how i can transition between each clip simultaneously.
See mockup for what I am trying to achieve:
https://youtu.be/TVaDSdk55oU/
Thanks in advance!
RVBVideo
Re: Slide between multiple video clips
Post by RVBVideo »
you're looking for the layer transitions drop down. next to every layer there is a T vertical fader (just before the first clip on that layer) that controls the transition time between clips. just below the fader there is a small button that defaults to Alph. click on it and set to your desired slide. adjust clip times and transition time to suit :)
if you can't see the above turn on 'show layer transition controls' in the view dropdown tab at the top
Empyfree
Post by Empyfree »
In addition you will probably want to turn autopilot on to do the automatic progression for you.
Use the "Push" transitions and autopilot and this should give you the result your after :)
kurt_j_g
Post by kurt_j_g »
Awesome guys, thanks for the tips. I will give this a shot and let you know how it goes.
