Mapping Loop - Bounce To Different MIDI Keys
idrajit
Post by idrajit »
I'm new here, so excited to have found this software! Spent like 8 hours setting up my apc the past few days.
My question is, I would like to shift back and forth from the loop and the bounce options in an effect. For example if I have an effect on that increase the scale in my footage, i would like it to switch from looping the frequency to start over and over, to bounce back and forth.
When I try to map the bounce button to one key i manage to map it, but then when i try to map the next key to the loop function it just forgets the previous mapping.
Any way to do this?
I guess the broader question here is: I know one button can trigger different commands at once, but can different buttons trigger one command?
Re: Mapping Loop - Bounce To Different MIDI Keys
Yes: https://resolume.com/support/en/midi-sh ... ific-items
basically, you'd right click - duplicate the shortcut, leave the mode for the original on loop, and and set the mode on the duplicate to bounce.
You don't even need two buttons for this.
