Resolume 7.3.1 Toggle Clips, Optional NDI PTZ
New Clip Trigger Style: Toggle
With the Toggle Clip Trigger Style you can click on a clip to start it, click it again to stop instead of the default restart. Click, start, click, stop. Start. Stop. Start Stop. Start. Stop!
NDI PTZ Optional Options
The Pan, Tilt & Zoom options on NDI cameras are now optional so you can control PTZ externally and Arena will not apply the PTZ when you do not want it.
HOTFIX 2
#14797 This Deck, and This layer shortcuts disappear after some time, switching decks, or adding layers
#14800 Shortcut mapping group columns selects multiple columns
HOTFIX 1
#14778 Acuarela effect can not be found in composition
#14790 Acuarela destroys alpha channel
#14779 Text renderers render lines with an offset, sizing text moves vertical line center
#14783 Can't shortcut map crossfader
#14785 Cue point set button shortcuts no worky
Fix List
#14374 Prores renders are not recognized properly by Adobe
#14414 Infinite Zoom effect needs a reset button
#14430 This Clip shortcuts show like they are not assigned any more after adding layers, weirdly they still work
#14494 Speed(multiplier) slider of transport can be changed with scroll wheel when mouse is over
#14499 Soft edge parameters should hide when soft edge is off
#14566 Keyboard shortcut in Value mode sets param both on key down and key up
#14624 "This..." Midi shortcuts break after a few triggers in 7.3.1
#14717 Crash loading composition with envelope end point moved from range end
#14730 Crash changing layer/column/clip color via top layer menu
#14731 Crash setting mask effect Image parameter to Timeline
#14733 Crash when dragging envelope end keyframe
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update. Or checkout the downloads page.
goblin@nurbs.ch
Re: Resolume 7.3.1: Toggle Clips, Optional NDI PTZ
Post by goblin@nurbs.ch »
Interesting changes, thank you.
I could be wrong, but after updating no maping on A -- B Cross-Fader?
Best regards
Oli
goblin@nurbs.ch wrote: Sun Dec 13, 2020 13:12 I could be wrong, but after updating no maping on A -- B Cross-Fader?
yes, http://resolume.com/forum/viewtopic.php?f=12&t=20243
