Autopilot Start / Stop on OSC
goblin@nurbs.ch
Post by goblin@nurbs.ch »
Can some on help me?
Try to switch the Autopilot ON/OFF, but on OSC Mesage "/composition/layers/1/autopilot" Value 0 - 1 it switch between "backwards" and "random".
OSC Type Tag= Int 0 trough 3, but also with value 2 - 3 it doesent stop or start.
Any idea?
Re: Autopilot Start / Stop on OSC
Setting Int 1 sets layer auto pilot to OFF for me.
Sending 0.3 f to /composition/layers/1/autopilot also works for me.
Are you sure you're sending int 1 ?
Which Resolume version are you using?
goblin@nurbs.ch
Thx for that fast answer,
Ok now i have it. You bring me on it.
AUTOPILOT OFF = Sending only 0,3
AUTOPILOT >> = Sending only 0,6
AUTOPILOT << = Sending only 0
AUTOPILOT X = Sending only 1
For me thath works... it is that what it should? :?
This should work with floats with these values, yes.
