I use the "push left" transition to make endless, looping horizontal video.
But the 10" maximum layer transition seems too few to me, to reduce the speed I would need to set it to 30 seconds
Transition layer more than 10 second, 30"?
Re: Transition layer more than 10 second, 30"?
Have you tried the slide fx then animating it and slowing down the speed?
Infinite137
Re: ¿Capa de transición de más de 10 segundos, 30"?
What you say does not help me.
Only 30 seconds maximum, in the layer, they would help me
It is at this point where I can change the scroll speed. Affect everything behind programmed all at once.
In a way I think that I take advantage of a defect in the resolume that serves as an effect. Transition layer push left of 10 seconds, which changes a row of many video routers with a duration of a couple of seconds like autopilot.
With the result of a continuous image without separations in horizontal scroll
But 10 seconds is too fast to pass a whole video from side to side horizontally
Sorry, I'm not following your reply.
You asked for a way to make an endless looping scrolling video but longer than 10 seconds. Using the slide fx can achieve this, you can even specify the time it takes to make a full cycle, then you can animate the speed slider under it to speed it up or slow it down. like this:
Is this not what you are asking for?
Infinite137
No.
and the following videos?
At the end of one the next must be placed in perfect union. 14 clips in a row seamlessly joined and then looped over.
For only one your option is a good idea
And I don't want to make a canvas 15,000 pixels wide to add the 14 clips in a row
Gotcha! I thought you where only wanting to do this on one video. I would just use a compositing software and bake out these transitions
