Hey guys,
I am not sure what the cause of this bug is, but even though i have resolume updated and everything it keeps crashing non-stop. I mostly use resolume nowadays to input my webcam and then output it via spoutcam to any video chats im in, and add effects to my camera. I don't know if that has anything to do with it. Anyways lately no matter what it will crash at some point. I don't know if it is when I alt tab, although that's what I've been suspecting, but it just crashes non stop every time I use it.
Let me know any additional info needed to solve this, I sent the error report when it happened.
Crashing all the time.. alt-tabbing/cam input
Re: Crashing all the time.. alt-tabbing/cam input
Send in the crash logs so they can see what the cause is. 99% of the time it is GPU driver related. what GPU and OS do you have? Are your drivers up to date?
We know of an issue where running spout output from Resolume in dx9 mode can lead to a crash and are working on it.
I'd recommend to disable dx9 functions using SpoutSettings.exe, which is part of the Spout installer you can get at https://spout.zeal.co/
This is just a guess, that it could be the reason in your case, we'd need the crash report to be more specific
