Resolume mapping on sphere
kevin
Post by kevin »
Dear,
I have event mapping on the sphere, I searched in forum and have a bit information about this but still want make sure have some pro guy did it with resolume before.
I will use 3 projector portrait to mapping 220 degrees on the sphere diameter 7m.
I also bought the small balloon to testing, I feel still can do but need time for fine tune.
Hope anyone did it before can have some idea.
Many thanks,
mrlupin
Re: Resolume mapping on sphere
Post by mrlupin »
following
I remember a user who wanted to map a big balloon a while back, the issues came when the balloon started moving around in the wind.
With one projector it's probably not that big of a deal, but when you have edge blending going on, the blends can get out of alignment easily if the object moves.
How's it going with the small balloon for you?
