Multiple Select MIDI mapping.
djrummer
Post by djrummer »
Hi!
Just throwing more ideas out there.
I just spent an hour mapping MIDI note 1-128 on 16 layers, one for each channel.
Now, I need to select Input / Output / Target.
I would really love to be able to select more than one MIDI clip and apply a change of all XXXX variable.
also, my lighting program, Enttec's DPro allows to select XX cells, MIDI trigger the first one, and then it auto populates the next ones sequentially for XX notes chromatically.
Re: Multiple Select MIDI mapping.
Target is remembered if you map the same type of shortcut.
Input - output is set automatically if you set the shortcuts up using actual input.
+1 to multi selection shortcut edit.
djrummer
Post by djrummer »
Zoltán wrote: Thu Feb 18, 2021 11:50 Target is remembered if you map the same type of shortcut.
I know I'm a rare use case - but i dont map the MIDI with what I end up using - and what I use changes often.
but thank you for the multi possibility.
*goes back to clicking each clip one by one for 16 channels*
djrummer
Post by djrummer »
another functionality included would be a way to keyboard stroke up , left, right, in the MIDI mapping window.
select different clips MIDI via keboard.
Thanks. :)
