Building a new system and was wondering if anyone had used the
NVIDIA Quadro T2000, 4 GB GDDR5, 128 Bit
on their servers?
if so, are there any bugs ?
Anyone use NVIDIA Quadro T2000, 4 GB GDDR5, 128 Bit
AGLsystems
Re: Anyone use NVIDIA Quadro T2000, 4 GB GDDR5, 128 Bit
Is this a GPU you have sitting around and are trying to use? What are you after by using the Quadro card? Geforce card will outpower the quadro line for less than half the cost. a 4GB quadro card isn't going to give you fantastic performance if you're trying to do large rasters. 1080p you're fine.
