Creating Offset fixtures for Pixel Mapping
rolandmc
Post by rolandmc »
I'm likely to have to be pixelmapping several of these panels: https://rupixels.com/panel
Is it possible to create a fixture that has these offsets in the pixel layout? Also, is it possible to create a fixture that spans 4 universes?
Or do I need to just create several lines of pixels and offset them myself? If this is the case, is it possible to "lock" them together in the advanced output so I can easily move them around and rotate them as a group?
Thank you.
Re: Creating Offset fixtures for Pixel Mapping
Moved to feature requests.
We're looking into the multiple universe spanning, and I think we also have a ticket to have freely configurable fixtures, which would include changing the physical pixel layout.
Meanwhile the manually shifted strips could work.
You can do multi selection in the advanced output, so you can move and rotate the fixtures together.
