Taking care of your laminate floor with the best mops of the year
davehetfield
Post by davehetfield »
Everybody knows laminate floors require special treatment to help them keep their beauty lasting with time. People try to not damage it, not stain it, using the best store-bought cleaner solutions to apply on that flawless surface. But the best way to take care of your laminate floor is daily cleaning with a suitable mop and some homemade cleaner solutions. And that is what you’re going to find out in this post: the best mops for laminate floor and 4 homemade laminate floor cleaner formulas you can try right away with things in your cabinet.
Top 8 best mops for your laminate floor
1. Microfiber Wholesale 18" Professional Mop
With an 18-inch wide cleaning head, this mop is perfect for a large cleaning job. The mop pad is made of microfiber which absorbs excess water like a pro while leaving a streak-free finish. This mop also has a dust pad for dry cleaning, and the best part is both mop pads are reusable. You can throw them in the washing machine to cut off the extra work. The handle is sturdy and can be adjusted to fit different members of your family. We’re giving the Microfiber Wholesale 18" Professional Mop 7.5 points for the overall score.
2. Bona Microfiber Floor Mop
The Bona Microfiber Floor Mop is our runner-up in the large cleaning job category with the 16.5 inches mop head. Along with the extendable handle which has a maximum length of up to 60 inches, cleaning under furniture or even above the floor is not a hard job for this mop. You can navigate the 360-degree swivel to every corner of the house easily. With two mop pads, one for dry cleaning and one for wet cleaning that can be machine washed 500 times, you can save plenty of recurring costs. We’re giving the Bona Microfiber Floor Mop 7.0 points for the overall score.
3. Nellie’s Wow Mop
Cordless, lightweight with an automatic liquid-delivery system, who can say no to the Nellie’s Wow Mop? This electric mop helps you clean the floor effortlessly. No need to use pressure to scrub, no need to carry a bucket everywhere you go. You just have to glide the mop on your laminate floor and let the machine do the rest. The cleaning pads oscillate 1000 times per minute to clean the floor while the built-in water tank distributes liquid. All you have to do is control the water level with a button. We’re giving the Nellie’s Wow Mop 8.0 points for the overall score.
4. Oshang Flat Floor Mop and Bucket Set
The Oshang Flat Floor Mop and Bucket Set is an old-fashioned way to clean your laminate floor with essential improvement to make the process more efficient. Traditional mops have a big disadvantage which can bring back dust and dirt to the floor after several times dipping it into the bucket. But that is not the case for this mop. The bucket has a washing groove to wipe out debris before you dry the mop in a separate compartment. Plus, this is a hand-free design so you don’t have to lay a finger on the mop pad when removing and attaching it. We’re giving the Nellie’s Wow Mop 6.8 points for the overall score.
5. O-Cedar ProMist MAX Microfiber Spray Mop
Don’t you hate it when you have to stop in the middle of the cleaning session to change the mop pad? If you do, then the O-Cedar ProMist MAX Microfiber Spray Mop is the best mop for laminate floors you can count on to fix that problem. With a dual-sided mop pad, you can easily flip one side over when the other is dirty. This mop also has a manual control spray bottle to distribute water while you work so no bucket is involved. We’re giving the O-Cedar ProMist MAX Microfiber Spray Mop 7.8 points for the overall score.
6. O-Cedar EasyWring Microfiber Spin Mop
If you’re looking for a mop that can get to small corners, then the O-Cedar EasyWring Microfiber Spin Mop is your answer. With a unique triangle mop head and an extendable handle, you don’t have to bend or stoop to clean hard-to-reach areas with this mop. The fluffy strands on the mop head are incredible with capturing dust and grime. While you can wash it with the spin system, you can also throw it into the washing machine for a deep clean every once in a while. We’re giving the O-Cedar ProMist MAX Microfiber Spray Mop 7.5 points for the overall score.
7. O-Cedar Dual-Action Microfiber Flip Mop
Just like the O-Cedar ProMist MAX Microfiber Spray Mop, the O-Cedar Dual-Action Microfiber Flip Mop also has a dual-sided mop pad. The difference is this dual-sided pad has one side for gentle mopping while the other is for scrubbing. You don’t have to carry a separate cleaning pad to change when there is a stain that needs some extra force. Just flip the mop and you can tackle the spot right away. We’re giving the O-Cedar ProMist MAX Microfiber Spray Mop 6.8 points for the overall score.
8. Rubbermaid Reveal Spray Mop Kit
For those who usually have stubborn stains on their laminate floors, the Rubbermaid Reveal Spray Mop Kit would be their favorite mop on this list. Besides the microfiber mop pad, this mop offers an extra non-scratch scrubber for special debris treatment. Other than that, this spray mop is manual so anyone can quickly learn how to use it. The 22-ounce refillable bottle allows you to use both water and a cleaner solution. We’re giving the O-Cedar ProMist MAX Microfiber Spray Mop 8.0 points for the overall score.
Top 4 homemade cleaner formulas for your laminate floor
Formulas 1: rubbing alcohol and vinegar
Mix equal parts of distilled water, vinegar, and rubbing alcohol in a spray bottle. Then add your favorite essential oil into the mixture to your liking. Shake the bottle to create the magical formula.
Formulas 2: vinegar and water
Combine 2 parts distilled water to 1 part vinegar in a spray bottle and mix it well. This one is the easiest formula out of the 4 homemade laminate floor cleaner formulas you can try right away with things in your cabinet.
Formulas 3: Dawn and rubbing alcohol
Add 1 cup of distilled water, 4 tablespoons of rubbing alcohol, and a small squirt of Dawn in a spray bottle. Then shake the bottle gently to mix the formula. This formula is perfect for people who don’t like the smell of vinegar.
Formulas 4: soap and water
To create a streak-free solution with soap, mix 2 drops of castile soap with 2 cups of distilled water in a spray bottle. Then add a few drops of tea tree oil and your favorite essential oil to the solution. Finish things off by shaking the bottle to mix the formula.
We hope there is the Best mop for laminate floors: Your TOP choices in 2024 upon our list. Don’t forget to use one of the 4 formulas to get the best result.
Re: Problem first frame. Need help!
Are you using DXV videos?
