Can't Drag Decks / change order UI bug
oliviano
Post by oliviano »
When I try to drag decks around in one of my projects the UI doesn't behave properly, and every time I drag a deck left or right to re-organize it, the UI doesn't allow me to do so, instead of holding it scrolls through.
Seems like a composition corruption or I may have too many decks? ( 20 ish )
cheers
-- Windows 10 Pro - Gigabyte Aero x15 - 32gb - 1T nvme - Rtx 2070 - Resolume Arena 7
Re: Can't Drag Decks / change order UI bug
Which Resolume 7 version are you using?
visions
Post by visions »
Same here! I have a huge amount of decks, so I have to scroll horizontally with mouse wheel. Since first resolume 7 (or so), when I drag a deck in order to organize it, the whole decks scrolls so the deck remains in the same position...
Alerady fixed in 7.3.2
You can get it from our download page http://resolume.com/download
