record in many monitors view
elbundlo
Post by elbundlo »
Hi there,
Is it possible to record in the 'Many monitors' view?
I can't see the record button in this view. It's visible in all other views.
Cheers...
Re: record in many monitors view
Not quite sure what you mean,
would you like to record your advanced output?
An external recorder via Syphon/spout or NDI would be great for that, something like OBS, for example.
elbundlo
Post by elbundlo »
No, I just mean the 'record' button is off screen when in the layout called 'many monitors'.
It's no big deal and I'm using OBS to record output anyway...
Could you send us the layout preset, and a screenshot of how it looks on your machine?
