Mixer Knob Zero Value Assignment
lmilianl
Post by lmilianl »
Hello Resolume Forum,
I am just getting started to understand Resolume, especially in the combination with a Denon Prime set up. Now my question:
I want to assign the Filter knob on a denon X1800 to a distortion effect. My Problem is that the filters knob zero value is exactly in the middle of the rotation knob. If you turn it to the left you get the LPF, to the right HPF and in the middle it is off.
How can I tell Resolume that the zero of the effect is not completely left on the rotation knob? I saw it in the demonstration that it should be possible:
https://youtu.be/70QmuVPYKAw
Same thing applies than to the EQ knobs. In the Demo they could manipulate the color but also the zero value of EQs is in the middle not on the left side.
Thank you in advance.
Ps: a tutorial video of the demonstration would be very helpful for the Denon Prime integration.
Re: Mixer Knob Zero Value Assignment
Try envelopes: https://resolume.com/support/en/envelopes
Also have a look on the StageLinQ setup here:
https://resolume.com/support/en/sync-to-denon-players
You know, you get 20% discount coupon for Resolume, if you buy a supported Denon DJ Player, right? ;)
You can claim it after registering your player on https://denondj.com
