Changing layer blend mode not working when abusing Autopilot
Hey Resolumes,
found a little hickup.
When you jump very fast from one clip to another via autopilot, changing the layer blend mode sometimes is not possible.
I added you a composition where I simulate that issue with two solids in rapid autopilot 8-)
- Open Comp
- Trigger first clip/solid
- Change "layer blend mode"
= if you are lucky, it changes.
Best wishes
layer_blend_mode.avc
(18.41 KiB) Downloaded 371 times
Re: Changing layer blend mode not working when abusing Autopilot
Can you try the same in 7.3.3, it seems to work fine for me there.
Hey Zoltán,
just tried it with 7.3.3
...for me the issue is still there. Please try to hop between "50 Subtract" and "ADD"
Between these two the issue seems to appear more often.
Best wishes
- Arena 7.3.3
- Win10
- 1080Ti
- External Display attached, but not in use
Interesting, seems to only happen on windows.
We'll see what we can do.
