Notch Block support
VjCtrldChaos
Notch Block support
Post by VjCtrldChaos »
Hey Captains,
I did a search on here but couldn't find anything.
Is Resolume considering adding Notch Block playback support? I brought it up on the Notch forum, and was told that the API needs to be implemented on the Resolume side.
I understand Wire is coming and that is a node based solution, but would love to be able to play Notch blocks natively in Resolume with exposed parameters, without needing to Spout/NDI signals in from the standalone software/capture card from another machine.
Alternatively, is TouchEngine support planned for Wire?
Cheers
Marchie
Re: Notch Block support
+1 for TouchEngine as well ;)
VjCtrldChaos
A year later any potential for this to become a thing?
Nope
Bassindaniel
Post by Bassindaniel »
You can always run it with Touchdesigner or any other software and use it as NDI source.
matinthehat
Post by matinthehat »
Yes Please!!
I know we have wire now, but please open it up to Notch and TouchEngine 🙏
Running Notch through TouchDesigner is an option but requires a full licence to use anything over HD
matinthehat wrote: Wed May 04, 2022 22:25 Yes Please!!
Still cheaper than Notch ;)
Vj Lab
Post by Vj Lab »
+1 for TouchEngine :shock:
