Alley problem
Re: Alley problem
just replied to your mail ;)
Please check your system meets the Minimum System Requirements. https://resolume.com/software/specs
If you believe it does, please update your graphics drivers, and/or make sure Alley is assigned to your dedicated GPU and your primary display is connected to the renderer card.
If you still have issues let us know and we'll try to find a solution!
