Any examples/advice on FFGL audio input for creating visualizers?
domegod
Post by domegod »
I saw from the release notes that "The FFGL plugin standard is updated to version 2.0. Plugins can now receive Audio FFT input to create audio visualizers."
However from looking around the repo, I cannot figure out how to use it.
I was able to get a parameter here:
Code: Select all
std::shared_ptr< ffglqs::ParamFFT > audiofft;
AddParam( audiofft = ffglqs::ParamFFT::Create("AudioFFT"));
I see that I now have an FFT with 2048 samples. However, when I check the values, they are all 0. Also, the calls I make to fns like GetBass(), GetVolume() etc. also return 0. Am I accessing the data wrong? Trying some expressions like
Code: Select all
this->audioParams[ audiofft ].GetBass()
audiofft->fftData[ 50 ]
Also tried using this directly in my frag shader like
Code: Select all
uniform float AudioFFT[2048];
but no luck there either.
I see my plugin & parameter in Resolume and I'm pretty sure that part is configured right - tried with both Composition and External audio. Just feeling pretty lost with the c++ side of things and haven't found any info when I search. Any help would be appreciated!
Menno
Re: Any examples/advice on FFGL audio input for creating visualizers?
Post by Menno »
I'm not sure about the ffglqs classes, but if you're able to use standard ffgl you could have a look at the particles example inside the ffgl repo. It creates an fft input and uses the values to control the number of particles that spawn for each bin. To see the effect in arena you need to play some audio in one layer and the plugin in another. Also the number of particles need to be raised, the plugin itself is kind of broken, but the information on how to use fft is there.
ANimator
Post by ANimator »
I agree that there should be more examples of how to use the FFT input in the examples. Having a simple EQ visualizer example in the docs would go a long way. Not sure why one wasn't included in https://github.com/flyingrub/ffgl/tree/more/ or https://github.com/resolume/ffgl. How are we supposed to make the most of our features if no docs are provided...
Would welcome anyone sharing any progress or demos they have.
flyingrub
Post by flyingrub »
https://github.com/flyingrub/ffgl/blob/ ... ea.cpp#L64
There is an example for fft input in here :)
