Load multiple images for slideshow
Peng
Post by Peng »
Hello all,
i am trying to create a bpm synced image slideshow in Arena.
I tried several ideas already but couldn't get there yet.
Its a really simple idea: on every beat comes a new image.
Bonus would be overlapping / crossfade effects of the blend mode
Is that maybe doable in Wire?
Re: Load multiple images for slideshow
This is currently achievable using the BPM transport method for your images and autopilot.
Peng
Post by Peng »
Thank you Arvol, i have tried the autopilot in this regard already but didnt get it snappy.
Could you please send me an example of your method?
Peng
Post by Peng »
I just figured what you mean and yes, this is a way to do it.
It is a bit tricky to control but it works :)
Thank you.
Peng
Post by Peng »
Cheers for that link, editing the whole layer at once is a big help here!
Converting the images to DXV should help a lot with responsiveness ;)
If you use Alley, you get 1 frame DXV files from image input.
Peng
Post by Peng »
Thank you Zoltán that resolved the chopping!
Peng
Post by Peng »
I just found this in the Alley manual:
Image Sequences
You can use Alley to convert an image sequence into a video.
Save your sequence in a separate folder, and make sure each image is named sequentially. Next, drag the folder in to Alley. Alley will see that the files are supposed to be a sequence and will display, cue and convert them as a single file.
But when i convert 5 images into a sequence, only one image is playing in the resulting .mov.
After loading the images in Alley, it does say "Image Sequence" but even in the preview i can only see one image, no matter where i move the playhead to.
Files are named image 001, image 002, ...
Anybody here knows how to make an image sequence that plays all images in one file?
Image sequences are a special pack of image files.
Only they need to be in a folder, and they have to be named sequentially.
But this will make 1 video with 1 image as 1 frame, 30 images will be 30 frames in this video.
If you'd like to do a slideshow, with fading and timing options, individual files is what you're looking for, like in Arvol's video.
