Hey guys,
I think it would be fantastic if I could set the fade time on a per clip basis instead of just per layer.
Technically this can be done with show control software and osc, but I feel like it's overkill if I'm only using it for Arena. Similar to per clip blend modes, there should be an option for it to be "layer determined" as well as having the ability to set it manually.
I primarily use Arena for linear cued shows, and I typically set up showfiles for other people to run so I have to write down the fade time for each cue for my operators which is not ideal. On top of this, allowing a longer transition time than 10 seconds (without having to use the envelope workaround) would be super handy as well.
