Column Switch - Audio stops for 3 seconds
vj harald
Post by vj harald »
Hello,
I have encountered a strange problem.
Have 2 Layers,
Layer 1: movie with sound
Layer 2: has movies without sound.
All movies are DXV encoded (1080p)
column 1
Layer 1: trigger mode restart
Layer 2: movie 1
column 2
Layer 1: trigger mode relative
Layer 2: movie 2
column 3
Layer 2: movie 3
column 4
Layer 2: movie 4
The goal is first trigger column 1 to start the sound, then switching between column 2-4 to change the movies in layer 2 while the sound an movie is continue playing on layer 1.
Simple tast i thought ;-)
It works well for around 10 times, then the audio stops playing for 3 seconds then automatically starts again at the right position of movie 1. video of movie 1 plays always as it should.
i am on pc, rtx 2080 super, i7, fast m2 ssd.
Beat snapping is off
What i tried:
changed audio buffer size from 512 to 1024 (has no effect)
Trigger columns with mouse or midi controller makes no difference.
Perhaps someone has a hint for me,
H
vj harald
Re: Column Switch - Audio stops for 3 seconds
Post by vj harald »
If someone has the same problem. Found the bug.
There was a second clip in the same column which had an silent audio track.
(was at -192db).
This clip was responsible for stopping the sound at the other clip for a few seconds.
vj harald
Post by vj harald »
Just want to share my experience
Trigger "mode relative" in a layer with AV clips are not always working, if you fire them via column trigger.
The audio stops for 3 seconds. This happens not every time. In my case every 10 times triggering my clips.
Are these DXV AV clips you see this with?
vj harald
Post by vj harald »
Yes, DXV AV clips. No alpha. No Audio compression.
After this happend during a show, I did not use column swith for this part ;-)
Hmm, this is a weird one, sounds like a ticket we have. Unfortunately it doesn't really want to happen in our testing.
Could you please send us the Resolume log file via the feedback tab in preferences?
barry
Re: Audio playback problem
Post by barry »
For our situation this happens on non looping clips.
When triggering the cell the audio starts a sec to late, not always but sometimes.
Add the fact that you don't know if the AV will stay sync as well.
barry wrote: Thu May 12, 2022 08:44 When triggering the cell the audio starts a sec to late, not always but sometimes.
When the audio starts does it start from the clip start, or is it in sync with the video at that point?
Hans_A
Post by Hans_A »
when the audio comes in after 2 seconds, it is sync with the video.
Having the same problem for quite some time now with Arena 7. 6 is clean.
Hans_A
Post by Hans_A »
This is also OS independent. Having this issue on Mac OSX and Windows 10. So no audio driver issue it seems.
