Mapping with LED Processors
jrr0083
Post by jrr0083 »
Hi, I have a general amount of knowledge when it comes to LED walls and resolume. My question is my buddy's church wants to redo their LED wall configuration. The future setup will be a center piece with two totems flanking on each side with 2 other walls for IMAG. I was planning on putting the totems on the same processor as the IMAG walls so that both processors would have enough ports for redundacy backup. They are sending 2 outputs from resoume via a Quadro card to avoid video tearing. My concern is that with the totems being on a different processor that Resolume won't see it correctly. Thoughts?
Re: Mapping with LED Processors
Resolume sees what the processor gives to the computer. The LED wall layout is not something what is usually passed through.
You'll probably see something like a 1920x1080 or 4k display as the processor.
Give me your panel pixel count (wXh) and how many panels (wxh) you are doing for all slices and I can build you up a pixel map.
What processors do you have? Novastar?
