Sending Multiple OSC Commands When Clip is Played
derekg22
Post by derekg22 »
I am trying to send out multiple OSC commands to MagicQ to recall cues when a clip is played.
When I Edit OSC shortcuts, enter a custom command tied to the clip, it doesn't let me add another OSC command. I CAN however duplicate the OSC command - which gives me duplicates, then I can change the text being sent.
However this doesnt seem to work.
Does anyone know how to do this?
deflost
Re: Sending Multiple OSC Commands When Clip is Played
Post by deflost »
hello, we have the same problem. does anyone know a solution?
thx.
r.h.
westfernsehen, leipzig
Use Chataigne to ingest one OSC command and output multiple.
