Hue Key Picker Input Node for Wire
sonofx
Post by sonofx »
Hello,
Is there a way to configure and input node for Wire that allows the user to select a hue key?
I'd like to feed a user selected hue value from Resolume into the ChromaKey node inside Wire.
Maybe there is a way to use the float4 from the Color In node to calculate an approximate hue key value (0-1)?
Thanks in advance.
