Hello,
I'd like to use the chromakey effect in a wire patch, and want to make the key hue available as a user input within resolume. Potentially an alternative approach would be to have a RGB to HSV node in wire, so the chroma key could be calculate based on an RGB/A input node. Touchdesigner has an RGB to HSV TOP, so something similar would be nice.
Joe
ChromaKey Input Node and/or RGB to HSV node
Re: ChromaKey Input Node and/or RGB to HSV node
Ticket has already been requested for this on Slack. I built out the logic for the conversion in Wire using other Nodes, but a single Node would be nice. Hoping it will come out soon.
The formula can be found here: https://www.rapidtables.com/convert/col ... o-hsv.html
samTrolland
Has there been any updates to Wire to do RGB to HSV conversion since this post?
Or is Arvol's answer of manual conversion via multiple nodes still the best option?
