Extremely Low frame rate on WX9100
Retinakiller
Post by Retinakiller »
Running R7 with 3 UHD outputs all locked to 50hz. When I output, even just black, my frame rate dives to about 15fps. I’m guessing there’s some sort of setting or software/firmware bug as this card should be able to handle this no problem. Has anyone run into this and come up with a solution?
Re: Extremely Low frame rate on WX9100
Are you running your main display on the same GPU?
