Auto instancing
tenko_jp
Auto instancing
Post by tenko_jp »
Can the Wire dynamically expand / contract the array?
For example, when I put multiple "Circle Patterns" and switched with "Switch", I confirmed that the following nodes were expanded / contracted.
I think it would be nice if an array of general source nodes, not just "Circle Pattern", could be dynamically expanded or contracted without using "Switch", but is there a way?
(This sentence is an automatic translation, sorry for the poor sentence)
Re: Auto instancing
I'd use Gate for switching.
The Gate will do an expand to the highest instance count for you, your input instances will be repeated to fill all the instances.
--begin-wire-patch--
491.3oc4UEraiCBD8WYEmsiv.1Xxs1jp8ZuG4CDaZBZcfHLtcai7+9NfyljtsoUsU8v1ZK4wL9Mi48lAXGp1ZLpZu1Z5PSWrCciytAdAmf1J8dkyfpRPdK3hlfzls8dLpZH4.vryCL6Q.ImGHA.B9L1FELI1gvgG.VmdYuez0Ms16BV+8aUnoiCSP2Ja6CC6zqLxVz.7KrZiu6Djl9MKUtiXyvC.rk1dSSD1Zkd0ZOZZIL+tS23WCPD4IneCVFXuGrEBHj5VYWLBcCjVJkP3jh7zBJcdJilyRu7p4kob5U34TLkxmwC+TkqCjVzTbLC15eAwdqtQYgOVaast.YfqBIFGcY57x8LPZV0pdLok9SXBjRmrQ22cdL3I4A5tV2znfYwhfJK2D.NS6paU+358kD.T1mopSdCpdYT0oEkeGTcxmnpSe6854X92AUm99UccbVWqdEgOA0oZG2XMcD0AzQywTCEQ0JH5PH5GTuTZAHubthRBA87k8LbwSp6LV4DAlHxYY3r7BxXW.LdhHiCNywTAFb+jlBNuPL1TTJDorKDyRKIWbYpfI3YEPSAig+nME6Ot4ep3ji7cAbNEtJ4+pmUCGNd7KJwHeAI1gEymvs+tv8H4.zu26pyr20OkdUb8rS0Y6ci66LL7G7U7XuE
--end-wire-patch--
