Next/Prev Layer Select for MIDI map?
tawm
Post by tawm »
I would love to use the up/down arrows on the apc40mk2 to select the next or prev layer.
Is there any way to map this natively in Resolume? I could do it with Bome but right now I have no other need for Bome on this machine and would prefer to keep as few links in the chain as possible.
Thanks in advance and cheers to the year end!
Re: Next/Prev Layer Select for MIDI map?
Not currently, moved to feature requests.
tawm
Post by tawm »
Thank you, Zoltán!!
subpixel
Post by subpixel »
In some older version you used to be able to use the keyboard cursor keys to navigate up and down layers, and also left and right through the previews of clips in the deck (without launching the clips).
I havd 1,2,3,..,9,0 mapped to access the first 10 layers of my composition, but I often have more than 10 layers to access, and having to scroll the UI is not so convenient sometimes.
spiffylabs
Post by spiffylabs »
I would also love this feature! I just started launching into active layer, so that would be amazingly helpful for moving up and down the layers.
I need to do it wrong, before I can do it right.
vjcrabs
Post by vjcrabs »
YES!!!! This would be very usefull. hopefully you can buildt this in the next update.
