Resolume 7.9 | Preview Advanced Output Screens & Node Library Search
Preview Advanced Output Screens & CrossFader
Since version 7.7 you can create as many preview monitors you like and directly monitor layer and groups. We're now taking this one step further by introducing preview monitoring of screens from the advanced Output and the CrossFader. Open the monitor menu by clicking on the radar icon in the bottom right of every monitor.
Node Library Search Improvements
Version 7.9 changes the way you patch in Wire forever. The Node Library with search can now be brought up by double clicking on inlets & outlets and by double clicking on a wire. This makes patching sooo much faster! You can also now select a node, press CMD + ENTER on macOS and CTRL + ENTER on Windows to open the node library, search what you're looking for and press enter to the create the node, this way you can use the mouse even less and patch even faster.
Installing Wire Patches
Drop a compiled Wire patch onto Arena and Avenue and it will be copied to the correct folder and show up in the Wire category on the Effects and Sources panels instead of listed as a "normal effect".
Avenue & Arena Fix List
#14279 Update to FFmpeg 4.3
#16853 Swagger.yaml has wrong value type for clip Connected
#16584 Stutter when loading & triggering a clip with Syphon input
#16600 Recalling cue point when AV clip is paused, audio position is not recalled
#16691 Dongle no worky any more under Monterey
#16746 Green color fringing when outputting via Blackmagic cards
#16763 Option for Footage Installer to not launch app in /SILENT mode
#16838 Crash clearing clip slot through API
#16839 Black BG in Chinese translation says Black Beijing
#16842 Blend params can get lost when copying effect
#16854 Clearing layer through REST-API does not work
Wire Fix List
#16680 Crash inserting Pack before Node which already has float 4 connected to other inlet
#16688 Snapshot can create image from wrong node, move Snapshot to Node menu
#16754 Length isn't multi-class
#16755 Welcome dialog doesn't show thumbnails in recents
#16770 Crash connecting multichannel nodes using wire drop on background with nodes not accepting multi channel input
#16885 Bloom and Pixel blur are broken in Wire on M1 with Montere
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update, including Wire. Or checkout the downloads.
