META-TICKET: Wire for high quality video generation (and suggest separate Wire board)
webel
Post by webel »
Hi Resolume forum,
Firstly, thanks to the Resolume developers for your wonderful tools.
May I suggest that it would be good to have a dedicated forum board for Wire.
I'm not a VJ; I'm using Wire (sometimes together with Resolume Avenue) to create high quality video content - usually from high resolution macro photography or 4K video - which I then collate and edit on a Mac in ScreenFlow or Final Cut Pro. Over the next weeks I'll be adding some forum postings about my experiences with Wire, some bugs/issues/problems, and some feature suggestions. In the case of issues, most will have been already formally reported using email to Resolume, or less formally using the Feedback dialog under Preferences in Wire.
In making issues reports and feature suggestions, I am fully aware that the needs of VJs are not always the same as highest resolution content creators, so in some cases I'm asking the tool to handle things it might not have been designed for. Where appropriate I'll be providing the Wire and Resolume Avenue version numbers, but I won't always be providing version numbers of decoder/encoder tools like Handbrake or video tools like ScreenFlow or Final Cut Pro that I'm using.
Re: META-TICKET: Wire for high quality video generation (and suggest separate Wire board)
Right now the forum is not yet overwhelmed by wire posts to justify it’s own board. But pleas also join in on Slack where we do have dedicated #wire channel.
