Stumbled upon grandMA3 and needed to trigger Light-Cues via OSC. Found many fragments for answers and assembled them to a script in Processing to act as a bridge application that uses CLIP-NAMES in Resolume (where the cue number is stored) to send grandMA3 customised OSC-Messages.
Code: Select all
TRIGGERING CUES ON GRANDMA 3 WITH LAYER NAMES IN RESOLUME VIA OSC
THIS PROCESSING APPLICATION USES AN OPEN SOURCE OSC-SERVER TO LISTEN
TO RESOLUME FOR CLIP CHANGES ON A SPECIFIC LAYER THAT CONTAINS CLIP NAMES
THAT REFER TO AND TRIGGER CUE NUMBERS IN GRANDMA 3 SEQUENCES
THIS WAY YOU DON'T NEED TO SET CUSTOM OSC ADDRESSES IN RESOLUME
TO TRIGGER LIGHT CUES. ALSO A BLANK CLIP ACTS AS A 'WAIT' AND KEEPS
THE CURRENT LIGHT CUE UNTIL A NEW NUMBER IS BEING TRIGGERED
THIS IS POWERFUL IN MANY WAYS. ALSO FADES AND OTHER RESOLUME PARAMETERS
CAN BE CUSTOMIZED FOR YOUR PLEASURE BY QUICKLY GIVING CLIP NAMES.
THE FOLLOWING CODE EXPECTS RESOLUME TO HAVE BLANK (OR ANY) CONTENT ON A SPECIFIC LAYER.
IMPORT IS THE LAYER NUMBER THAT IS BEING SET IN VARIABLE:
int lightLayer = 3; // (NOTE THAT RESOLUME ALWAYS COUNTS FROM BOTTOM UP)
// HOW TO GET THERE:
0: BE IN THE SAME NETWORK AS GRANDMA.
1: PROCESSING
https://processing.org/download
2: INSTALL LIBRARIES FOR PROCESSING
In order to make OSC running in Processing
download and install oscP5 by Andreas Schlegel:
https://sojamo.de/libraries/oscP5/
On MAC save Library folder to:
> User/Documents/Processing/libraries/
// The following 2 libraries will available by then:
import oscP5.*; // OSC Server
import netP5.*; // Network
OscP5 OscP5; // Initiate server
// GUI and FONTS
int canvasWidth = 300;
int canvasHeight = 130;
int bigFont = 20;
int smallFont = 13;
String upper = "GRANDMA";
String middle = "...";
String lower = "PLEASE";
// Port for THIS Processing application
int incoming = 11000; // Incoming Port for THIS application = outgoing port for Resolume
// GRANDMA
int outgoingToGrandMA = 8000; // = Incoming port in grandMA3 Software
String IPGrandma = "10.0.1.33";
NetAddress GrandmaOscLocation; // Network object will be initated in setup();
// Resolume
int outgoingToResolume = 12000; // = OSC input port in Resolume
String IPResolume = "127.0.0.1"; // = OSC output port in Resolume
NetAddress ResolumeOscLocation; // Network object for sending OSC Messages
// COMMUNICATION VARIABLES
int lightColumn; // To store column once your navigating in Resolume
String lightClipName = ""; // To receive Clip-Name from Resolume
// INITIATION
void setup() {
size(300, 130); // Canvas width and height. freakingly it doesn't accept variables o.O
frameRate(25);
// Initiating OSC Server and Network Locations
OscP5 = new OscP5(this, incoming);
GrandmaOscLocation = new NetAddress(IPGrandma, outgoingToGrandMA);
ResolumeOscLocation = new NetAddress(IPResolume, outgoingToResolume);
PFont vulf;
vulf = createFont("vulf.ttf", bigFont); // ttf in data folder im sketch
textFont(vulf);
textAlign(CENTER);
// R E F R E S H ... every 25 frames
void draw() {
background(0);
// GUI STUFF
textSize(bigFont);
text(middle, canvasWidth/2, canvasHeight/1.95);
textSize(smallFont);
text(lower, canvasWidth/2, canvasHeight/2+bigFont*1.4);
text(upper, canvasWidth/2, canvasHeight/2-bigFont*1.5);
// O S C - L I S T E N E R
void oscEvent(OscMessage theOscMessage) {
// OSC-Messages mostly consist of 2 parts
// 1: The Pattern: which is a customised String coming from Resolume for a specific parameter
// 2: A Value: this can be an Integer, Float or String or more.
String addrPattern = theOscMessage.addrPattern(); // We only need the pattern to extract the Clips Position and Name
// Printing ALL OSC-Messages coming from Resolume EXCEPT position information
if(addrPattern.indexOf("position") <0 ){
println(theOscMessage.addrPattern() + " " +theOscMessage.typetag());
// LISTENING TO LIGHT LAYER
String[] m1 = match(addrPattern, "/composition/layers/"+lightLayer+"/clips/(.*?)/connect"); // If not null, then a match was found
if (m1 != null) { // If regular Expression is null, then it doesn't contain the pattern
if(theOscMessage.get(0).intValue() == 3){ // Integer-Value contains connection information. If '3' = New Connection
println(">> Connected to: " + m1[1]);
// IMPORTANT: Question to Resolume to ask for the name of the layer (containing the Cue-Number as a String)
askResolume("?/composition/layers/"+lightLayer+"/clips/"+m1[1]+"/name"); // REQUESTING NAME OF CONNECTED CLIP => function "askResolume();"
lightColumn = int(m1[1]); // Updating current column for navigation
// WAIT FOR THE CLIP-NAME
if(addrPattern.indexOf("/composition/layers/"+lightLayer+"/clips/"+lightColumn+"/name") >=0 ){
lightClipName = trim( theOscMessage.get(0).stringValue() ); // store and trim blanks (=spaces)
if(int(lightClipName) != 0){ // if String isn't an integer number, then don't send it to grandMA
sendToGrandMa(int(lightClipName)); // If yes: trigger OSC-Message to GrandMA
// ASK RESOLUME
// Funny enough: EVERY OSC Message can be used to send a request to Resolume by putting a '?' just in front of the message
// eg: ?/composition/layers/3/clips/1/name"
// this way Resolume will 'answer' by sending back the name of the clip to this application
// see: usage of this function 'askResolume' in OSC-Listener
public void askResolume(String question){
OscMessage Message = new OscMessage(question);
OscP5.send(Message, ResolumeOscLocation);
println("> askResolume: " + question);
// SEND TO GRANDMA
// after having resolved the Clip Name coming from Resolume, a String will be merged to serve grandMA's needs
// which will trigger the Cue-Number in the Sequence already programmed there.
public void sendToGrandMa(int cue){
OscMessage Message = new OscMessage("/cmd"); // "cmd" shall be added if there is NO 'Prefix' setted in GrandMA's Software
Message.add( "Goto Cue " + cue ); // grandMA needs only a String containg the function ('Goto Cue') plus a space ' ' plus the number of the Cue.
OscP5.send(Message, GrandmaOscLocation);
println(">> sendToGrandMa: " + cue);
middle = "Goto Cue "+cue; // variable for the GUI
Download Processing Script and Libraries: www.theaterdermitte.at/labor/GrandMA3-OSC.zip
Hope it helps.
Curious about your thoughts.
