Shortcuts: delete and undo
dennisbaptist
Post by dennisbaptist »
Might be asked already but didn't find the answer yet. Is there a keyboard shortcut to delete (clear) multiple clips? DEL-button doesn't seam to work.
Also there a undo-shortcut (CTRL-Z)? :?:
If there isn't, please implement it! Thank you!
Re: Shortcuts: delete and undo
dennisbaptist wrote: Mon Feb 14, 2022 19:06 Might be asked already but didn't find the answer yet. Is there a keyboard shortcut to delete (clear) multiple clips? DEL-button doesn't seam to work.
Control+X
dennisbaptist wrote: Mon Feb 14, 2022 19:06 Also there a undo-shortcut (CTRL-Z)?
Yes, would be pretty easy to try out ;)
Max Mugen
Post by Max Mugen »
ctrl + X is cut
not clear !!
and it is not the same thing
please be more precise when providing information as it is misleading. thank you
as far as I know, there is no shortcut for clear neither a way to bind it to a shortcut (to be confirmed)
wich honestly is a shame ..
