Resolume with ArtNet Node PixxControl doesn´t work
RyanMirror
Post by RyanMirror »
Hello all,
I am using Resolume with a DMX4ALL Artnet PixxControl and a 52 pixel LED stripe. The stripe was created in the fixtures. Also the interface is found at the output.
Unfortunately I can't get the control of the stripe to work.
The same setup runs with Jinx! I do not know what to do. Can you help me. Thank you very much.
Greetings
Re: Resolume with ArtNet Node PixxControl doesn´t work
What are the settings you use in Resolume and the pixel controller?
