problems handling on ClipEvent actions.
nayades
Post by nayades »
If I place any of the numeric variables ( rparameter1, rparam2... etc) inside an "on ClipEvent" action it wont work or work strangely while in resolume.
is this normal? any way I can fix it?
[The extension fla has been deactivated and can no longer be displayed.]
have you set the timeline handling to flash in Resolume?
