Custom colour setting for labels
jim
Post by jim »
Hi đź‘‹ all,
I find the label colours can be a bit subtle, does anyone else find this? The actual colours other layers and clips are much duller then the colours you select, see image bellow
I can understand why some people would want muted colours so as not to distract from their vjing composition, but others may be like myself who like to use bright contrasting colours for organisation. I did a mock up bellow of how I thought label colours could be included in settings. Obviously would want to match font size, I thought entering a hex code, with a validation test would be the easiest way to implement. But if a colour picker could be used even better.
Re: Custom colour setting for labels
It has already been asked, and the reply will most likely always be:
"No! You all need to keep your hands of our carefully designed interface and go ahead and splatter any color you like on your stages ;-) "
