Wired comps
mattblack
Wired comps
Post by mattblack »
got sent a wired comp, with a .cwired extension. where should it go to access it?
thanks
Re: Wired comps
Drop it onto the Resolume UI, and it will install it for you.
These go into the Public User's Documents folder/ Resolume Wire/ patches.
VJ footage: https://goo.gl/58oHy7
