Update fx's
Grimm90
Update fx's
Post by Grimm90 »
When changing the composition resolution (for example going from 1920x1080 > 3840x1080), all the effects and generators keep their resolution.
Would be nice to have a checkbox option to automatically update all these effects and generators to fit to the new composition resolution.
Thx
Grimm
Re: Update fx's
Try placing the effects after Transform.
If you select all clips, right click, there is a Resize option you can use to quickly fit/fill all of them to the composition resolution.
