Every time a note plays in Ableton, I send 3 OSC messages to Wire over OSC
/NOTE
/VELOCITY
/DUR
How can I ensure these three values stay grouped in wire?
Is there a way to pass an array to wire over OSC?
Synchronize multiple OSC data streams
Re: Synchronize multiple OSC data streams
Read them all using separate OSC read nodes, and pass them to a pack node.
Won't that generate a new collection each time 1 of the three messages comes in? Is there a way to hold three messages but not pass onwards until a trigger is sent, for example?
There might be a few ways,
Counter can count the messages incoming, then there is a pass N node which you can use to block the messages, and reset it with a Counter node.
Toggle nodes could be used on the inputs, with Set to True, and you could check if all are true, then pass the packed data, and reset the toggles.
--begin-wire-patch--
1440.3oc6YssbZiDD8WIkdlQdtzyM+lDWpMOsakj2h8CBz.nZAIWHQ7lMk+22VRXADIgIXRRsYWWtrgQmAOce5Kmd7W7lkkl5lUjjkl6c6G+h27MYqwWPG3kss3gsEd2OvqHCWggqjOy69mFz.RLv6gnMQqcEtMrFfpAd4thOrYq6Hv7NAK6FLqSvP2faeV4sOqsAIZCBZAxLvKIEWfdDNYu3XGgS0KN9Q3LOii1.TOnjZhSJYlyv0X67bxOIV1YPl1NOu11QGn+MOYQZzpi.hVQQEcc.rhMIKV31brQwa6AXrNsoxk+Zn0AFShVk6dQrxuArp9vR633J5731xC.caUvK3.te2qKyR8pvjlE6v28E7c3OhJP+5zsE0KkjlWDkNq9MEe9Am2sdoaWOEc6C79TzJ7.cK6omF3MMaaZbEpktjEKK7t0fTwiIwEKQDBzN+KuaAguFjfQHrFPnQO3mwGxX9JlxpTbPKkFoEeB9INaUTd8YHF+ip0JqlqjDEXrDHTOlDP4.IPRCXSfgfdLTdjbaxKCzukV8IjM6Ow89ojXWlWYdvprM36mieohnzpkpLvhcFaYj3dCsLqtwJS2tZUogtLIN1kV57pgW5.wfcD9u+9gu4sodHF1k5HOH0gr6omK7RPrCPW8qFrdyWkEU38xLkUVwTbg4Yxoep.LCABPweDnkJhgMRoYrgi.M+0REQwwab4G5rxQuY5hCrn6tYV15Gxxqprc2MUex2cia9brKT9c2TrIJMed1l02cS9rnUtRdojPOW5cOu9NWT7aPxshYoWN0VWViTi3j7jnOhRzhnzFvmxXRgTAfTv30IURI22.LsPZ1kq0OMFqjTBDEOkL0I4joT5by7o.RKtWKMtqR9dqcm40Xuej5K4JplJsf1nkVsRMf5KTBfiKQ4ZIyx4kqwQ6fZjJskJAbOBrrWSOfC7m6V4bX12mF8P9xrhJlsijV7z93wG9GOfpbexkVs05Zqj3j0tz7ZAPM64fE2az2ueSmNZ3Yio6vgxppeU3.no9TkfoYBClLZ1Uikvk9HUqoLtUXqiS5OfHX7XAVh0NhDFNBq3F3fgCGIiBEzqRIV5ERW+11oULEuqbvKhBt3laRS6RlJouPC.mxTJJSp1kJRJavQYBEFgiLiQ7RM3rwXU0HKiXhAGgyhvbgY1HFm8S06+NGJgox+KdEYJWSO9tZe.SH0.uIXWSs9LNHLVTqvoK8oln3DXrZDIHHPRFGNdxD.lv0pvqtu9UT5iZM3w0HEZtgaQS59d3nI65dfjD7ZKmclUlt9oQfuUiRD4n4uugFga7AA5ArTtQvomtBFDNdLJOQLgXmvMDVXfbBmwrhQg+fxgvVSIqceM8uGDsGFbjaUzmK8p7+8qgjqqnNtx9KhFxGuNhHE+xPsnfreQn1kWGpEttiPyZ44kTvmYTTqhYY.8YQFLF2WWNA.kpE75lgmfYhcJB3.JwpsnrethoiTSibPzgLC6JLCceUGatNjyBZ0U0cYxV9P1hE0S+I+IwMboxWY3ZpQic0EmVQx+MoF02apArVeTMAmovIi0hlKeBPs4njbTwtjJrkT1+SMGSM5uaWJXiJdguzfbBSPqu7uJlQnz93XrnbvWTEOL0FQhzyUDTubrUgJkmql8Z6wr+Vy2akSyxVs2FmWRE83.e67Rmm4mvcJvtjMw+F2Tdxe6NA6K5l8YT44R+LowWvjBqkor1Wne1vPIpzHPxPkFLKIfMBBgQlQxIWe49cEBz7+A4rfw6EV4E72S7TPZbYXg867n2kRFKP8hGFzOaYVxriDKxHUe60GKq5n0H0GLVCEynM1lVi3PuUC2JAigaN4HciGBXlNcjfDNNTQFpLgfZrgRCCNji4WsQ0OXVs1Cp2Ek2ZWsFkuqHfV6p08b1SDweDgFY4yPkvYa2TyrO8z+v8P3wq
--end-wire-patch--
--end-wire-patch--
Is there a way to pass an array to Wire over OSC in a single message?
yes, you can set the data you're looking for in the OSC read node:
- Attachments
- Képernyőfotó 2022-07-15 - 15.30.00.png (46.15 KiB) Viewed 2454 times
