Wire ISF vec2 snag
corlian
Wire ISF vec2 snag
Post by corlian »
Hi! I've got a common ISF shader that works fine in ISFEditor and Magic. It won't compile in Wire.
I get five of these errors:
Too many arguments to constructor of 'vec2'
Pretty sure they refer to the lines toward the end. In those lines, the vec2 is taking two floats so I'm not sure what's wrong. (inexperienced with coding though so who knows!)
Thoughts on how to get this to work? And/or, thoughts on why this behaves differently in Wire?
Code: Select all
	"DESCRIPTION": "VHS Glitch Style",
	"CREDIT": "David Lublin, original by Staffan Widegarn Åhlvik",
	"ISFVSN": "2",
	"CATEGORIES": [
		"Stylize", "Glitch", "Retro"
	"INPUTS": [
			"NAME": "inputImage",
			"TYPE": "image"
			"NAME": "autoScan",
			"TYPE": "bool",
			"DEFAULT": 1.0
			"NAME": "xScanline",
			"TYPE": "float",
			"DEFAULT": 0.5,
			"MIN": 0.0,
			"MAX": 1.0
			"NAME": "xScanline2",
			"TYPE": "float",
			"DEFAULT": 0.5,
			"MIN": 0.0,
			"MAX": 1.0
			"NAME": "yScanline",
			"TYPE": "float",
			"DEFAULT": 0.0,
			"MIN": 0.0,
			"MAX": 1.0
			"NAME": "xScanlineSize",
			"TYPE": "float",
			"DEFAULT": 0.5,
			"MIN": 0.0,
			"MAX": 1.0
			"NAME": "xScanlineSize2",
			"TYPE": "float",
			"DEFAULT": 0.25,
			"MIN": 0.0,
			"MAX": 1.0
			"NAME": "yScanlineAmount",
			"TYPE": "float",
			"DEFAULT": 0.25,
			"MIN": -1.0,
			"MAX": 1.0
			"NAME": "grainLevel",
			"TYPE": "float",
			"DEFAULT": 0.0,
			"MIN": 0.0,
			"MAX": 3.0
			"NAME": "scanFollow",
			"TYPE": "bool",
			"DEFAULT": 1.0
			"NAME": "analogDistort",
			"TYPE": "float",
			"DEFAULT": 1.0,
			"MIN": 0.0,
			"MAX": 10.0
			"NAME": "bleedAmount",
			"TYPE": "float",
			"DEFAULT": 1.0,
			"MIN": 0.0,
			"MAX": 3.0
			"NAME": "bleedDistort",
			"TYPE": "float",
			"DEFAULT": 0.5,
			"MIN": 0.0,
			"MAX": 1.0
			"NAME": "bleedRange",
			"TYPE": "float",
			"DEFAULT": 1.0,
			"MIN": 0.0,
			"MAX": 2.0
			"NAME": "colorBleedL",
			"TYPE": "color",
			"DEFAULT": [
				0.8,
				0.0,
				0.4,
				1.0
			"NAME": "colorBleedC",
			"TYPE": "color",
			"DEFAULT": [
				0.0,
				0.5,
				0.75,
				1.0
			"NAME": "colorBleedR",
			"TYPE": "color",
			"DEFAULT": [
				0.8,
				0.0,
				0.4,
				1.0
//	Based on https://github.com/staffantan/unity-vhsglitch
//	Converted by David Lublin / VIDVOX
const float tau = 6.28318530718;
float rand(vec3 co){
	return abs(mod(sin( dot(co.xyz ,vec3(12.9898,78.233,45.5432) )) * 43758.5453, 1.0));
void main()	{
	float	actualXLine = (!autoScan) ? xScanline : mod(xScanline + ((1.0+sin(0.34*TIME))/2.0 + (1.0+sin(TIME))/3.0 + (1.0+cos(2.1*TIME))/3.0 + (1.0+cos(0.027*TIME))/2.0)/3.5,1.0);
	float	actualXLineWidth = (!autoScan) ? xScanlineSize : xScanlineSize + ((1.0+sin(1.2*TIME))/2.0 + (1.0+cos(3.91*TIME))/3.0 + (1.0+cos(0.014*TIME))/2.0)/3.5;
	vec2	loc = isf_FragNormCoord;
	vec4	vhs = IMG_NORM_PIXEL(inputImage, loc);
	float	dx = 1.0+actualXLineWidth/25.0-abs(distance(loc.y, actualXLine));
	float	dx2 = 1.0+xScanlineSize2/10.0-abs(distance(loc.y, xScanline2));
	float	dy = (1.0-abs(distance(loc.y, yScanline)));
	if (autoScan)
		dy = (1.0-abs(distance(loc.y, mod(yScanline+TIME,1.0))));
	dy = (dy > 0.5) ? 2.0 * dy : 2.0 * (1.0 - dy);
	float	rX = (scanFollow) ? rand(vec3(dy,actualXLine,analogDistort)) : rand(vec3(dy,bleedAmount,analogDistort));
	float	xTime = (actualXLine > 0.5) ? 2.0 * actualXLine : 2.0 * (1.0 - actualXLine);
	loc.x += yScanlineAmount * dy * 0.025 + analogDistort * rX/(RENDERSIZE.x/2.0);
	if(dx2 > 1.0 - xScanlineSize2 / 10.0)	{
		float	rX2 = (dy * rand(vec3(dy,dx2,dx+TIME)) + dx2) / 4.0;
		float	distortAmount = analogDistort * (sin(rX * tau / dx2) + cos(rX * tau * 0.78 / dx2)) / 10.0;
		//loc.y = xScanline2;
		//loc.x += (1.0 + distortAmount * sin(tau * (loc.x) / rX2 ) - 1.0) / 15.0;
	if(dx > 1.0 - actualXLineWidth / 25.0)
		loc.y = actualXLine;
	loc.x = mod(loc.x,1.0);
	loc.y = mod(loc.y,1.0);
	vec4	c = IMG_NORM_PIXEL(inputImage, loc);
	float	x = (loc.x*320.0)/320.0;
	float	y = (loc.y*240.0)/240.0;
	float	bleed = 0.0;
	if (scanFollow)
		c -= rand(vec3(x, y, xTime)) * xTime / (5.0-grainLevel);
	else
		c -= rand(vec3(x, y, bleedAmount)) * (bleedAmount/20.0) / (5.0-grainLevel);
	if (bleedAmount > 0.0)	{
[color=#FF0000]		IMG_NORM_PIXEL(inputImage, loc + vec2(0.01, 0)).r;
		bleed += IMG_NORM_PIXEL(inputImage, loc + bleedRange * vec2(0.02, 0)).r;
		bleed += IMG_NORM_PIXEL(inputImage, loc + bleedRange * vec2(0.01, 0.01)).r;
		bleed += IMG_NORM_PIXEL(inputImage, loc + bleedRange * vec2(-0.02, 0.02)).r;
		bleed += IMG_NORM_PIXEL(inputImage, loc + bleedRange * vec2(0.0, -0.03)).r;[/color]
		bleed /= 6.0;
		bleed *= bleedAmount;
	if (bleed > 0.1){
		float	bleedFreq = 1.0;
		float	bleedX = 0.0;
		if (autoScan)
			bleedX = x + bleedDistort * (yScanlineAmount + (1.5 + cos(TIME / 13.0 + tau*(bleedDistort+(1.0-loc.y))))/2.0) * sin((TIME / 9.0 + bleedDistort) * tau + loc.y * loc.y * tau * bleedFreq) / 8.0;
		else
			bleedX = x + (yScanlineAmount + (1.0 + sin(tau*(bleedDistort+loc.y)))/2.0) * sin(bleedDistort * tau + loc.y * loc.y * tau * bleedFreq) / 10.0;
		vec4	colorBleed = (bleedX < 0.5) ? mix(colorBleedL, colorBleedC, 2.0 * bleedX) : mix(colorBleedR, colorBleedC, 2.0 - 2.0 * bleedX);
		if (scanFollow)
			c += bleed * max(xScanlineSize,xTime) * colorBleed;
		else
			c += bleed * colorBleed;
	gl_FragColor = c;
Re: Wire ISF vec2 snag
I wasn't able to see it do anything at https://editor.isf.video/
corlian
Post by corlian »
Ah, I must have jumbled it up somewhere along the way.
Here it is right from the ISF site. It won't load this code straight from the site into Wire either. Can anyone help?
https://editor.isf.video/shaders/5e7a7f ... 18206de6e7
This exact shader works great in Magic and ISF Editor (and presumably VDMX).
again this is the error message in Wire:
Code: Select all
failed compiling shader:
ERROR: 0:92: Too many arguments to constructor of 'vec2'
ERROR: 0:93: Too many arguments to constructor of 'vec2'
ERROR: 0:94: Too many arguments to constructor of 'vec2'
ERROR: 0:95: Too many arguments to constructor of 'vec2'
ERROR: 0:96: Too many arguments to constructor of 'vec2'
Interesting, made a ticket for our devs to check ;)
corlian
Post by corlian »
corlian
Post by corlian »
Zoltán wrote: Fri Jul 29, 2022 10:04 Interesting, made a ticket for our devs to check ;)
Curious if there has been any progress with this? Thanks :)
dirtyjohn_lv
Post by dirtyjohn_lv »
Have you tried?
Code: Select all
 vec2	loc = isf_FragNormCoord.xy;
Or
Code: Select all
 vec2		loc = vec2(isf_FragNormCoord[0],isf_FragNormCoord[1])
Normals usually have X Y Z
corlian
Post by corlian »
I hadn't tried those. I just did, and both versions give the same error as the original. Thanks for the suggestions!
