Simple Wipe Layer Transition effect
logreybeam
Post by logreybeam »
Hi! any chance of implementing a simple Wipe effect (up/down/left/right) as a layer transition? this would be Super helpful for a set-up i am doing.. i realize i can do similar with an automated crop and an extra layer per region that i want to wipe, but as im sizing layers as individual windows in a large interface that i want each to 'wipe' transition across columns, it would be Much more elegant if wipe was a transition option...
Thanks in advance!?
.gabe
Re: Simple Wipe Layer Transition effect
I built this out as a plugin called "Directional Fade" and it should be on Juicebar (who's website seems to be down atm??). I think it's $5.
Also available here: https://gumroad.com/l/directional_fade_pixel_party
logreybeam
oh awesome! just bought it, but ive never used any 3rd party plugs.. where should i put it so that arena see's it as a video effect?
Thanks!!
.gabe
just drag it in like a clip and it will ask you to install. then it will show up as a blend mode. under the blend mode drop down is where you can choose the direction
logreybeam
Got it, Thank you!! Super useful little tool, will definitely come in handy.. don’t suppose there’s a way to adjust the blur size of the wipe point? im basically looking to do hard wipes to simulate a scanning effect, turning a feed to a colorized(etc) version of itself with a simple layer transition. Thanks again
.gabe
Yeah, I'm going to overhaul it today. Update should come later this afternoon.
logreybeam
oh wow thanks! love it:)
.g
Today has been a nightmare lol. I'll get you sorted and built out on Monday. Sorry :)
logreybeam
no rush! thanks and have a great weekend :)
I've uploaded the revision on gumroad. Once we get a small bug fixed in Wire, I'll make the final version without the need for an ISF and then publish that to gumroad and juicebar.
Cheers
