Ability to uninstall wire patches inside Resolume
Hey Resolumes,
maybe it's just me...
When I am working with Wire I often go to multiple revisions or idea tests.
I build a patch and drag'n'drop it into Resolume to install and use it.
So my WIRE EFFECTS area under the Effects-Tab looks something like this:
RedEye_001
RedEye_001a
RedEye_002
RedEye_003
RedEye_003_Final
RedEye_004_NoNotFinal
RedEye_005
RedEye_006
RedEye_007_F*CKit
adasdasasdTEST
Mayonnaise
Moonrise_001
Moonrise_002
Moonrise_003
Moonrise_004
Moonrise_005
Moonrise_006
Moonrise_FINAL
Moonrise_FINAL2
EasyOutliner
Stringscatter_A
Stringscatter_B
Stringscatter_C
Stringscatter_D
Stringscatter_FINAL
Beatlooper_nowork
Beatlooper_willneverwork
SliceColorizer
Horizon_001
Horizon_00B
Horizon_003
Horizon_004
Horizon_005
Horizon_006
Horizon_007
Horizon_008
Horizon_009
Horizon_010
Horizon_FINAL
Horizon
You get the point :)
I would love to see a small trashcan icon
... behind the Wire-stuff in Resolume to be able to keep it tidy. Yes I know I can just delete them elsewhere ;) ...but
Best wishes
Re: Ability to uninstall wire patches inside Resolume
You can right click them in the effects panel and "Show in Finder/Explorer" to open them up in your OS file manager. You can then delete them quite easily.
A single delete button would be quite dangerous.
If you want to keep the old versions around, you can set the patch category in Wire to none, save it, and Resolume won't show the patch any more.
Yeah -1 for me, that would cause a lot more problems with accidental deletes (even with a prompt, I'd say no). Takes a few seconds to browse and delete.
I feel ya though, sometimes I have 50+ FX that are just concepts that never get finished, so I make myself do a cleanup once a week now :)
