is this feature avaibale in resolume
VJDefinitive
Post by VJDefinitive »
It would be good if you could assign certain clips to only go to a predefined layer on activation. i.e. If I had a black and white flasing avi, that i only ever want to go on the top layer with alpha transp. So when ever I hit that midi key, that is assigned to trigger that clip, i know its going to jump into the top layer.
Does this make sense? or is it avaiable already?
Danger
Post by Danger »
no that's not possible at the time...but is a god idea :)
continuity-B
Post by continuity-B »
I think it is possible through the midi assignment...
Danger
Post by Danger »
continuity-B: can you explain a little more your idea ?
levon
Post by levon »
you can assign midi for each clip to goto each layer, in the midi set up part click the numbers 1, 2, 3, for each layer
continuity-B
What he said
Danger
Post by Danger »
but that don't do exactaly what we were talking about...
the idea is to have that and more things
Tomos
Post by Tomos »
sweet! i've only been here 2 mins and i'm already learning ;) Hello every one by the way
Danger
Post by Danger »
imagine if you read the all posts on the forum ;)
continuity-B
what's the best codec?
