Switch clip synced on the same timing
Tonhiox
Post by Tonhiox »
Hello guys !
I'm starting on Resolume and I struggle doing something...
I explain the context.
I have a 3D render of an animation. This render is split in 3 different clip, each one have a different lighting. The thing I wanna do is to switch those clip based on the BPM to animate the lighting.
As its an animation I need to have them triggered all at the same time. I did it with the collumn trigger, but I can't figure it out how I could switch between them...
Cheers
Re: Switch clip synced on the same timing
Play them in separate layers and use Layer Master fader to show/hide them.
Crossfader could also work on 2 layers nicely.
Tonhiox
Post by Tonhiox »
Zoltán wrote: Mon Sep 05, 2022 11:55 Play them in separate layers and use Layer Master fader to show/hide them.
Thanks for your answer !
Well driving the Master layer, fade the opacity, but I'd like to link that to the bpm so its not fading the opacity but triggering it ON/OFF. I link the parameter to the BPM Sync but it doesn't give the result Im looking for.
For exemple I'd like to get the layer ON every 1, 2 or 4 beats and OFF as soon as it triggered. Is it possible to set that with the BPM sync ?
Tonhiox
Post by Tonhiox »
Ooow I think I just found what I was searching for by mixing the BPM sync with the envelope !
