Resolume not finding MIDI XML files
boris.lema
Post by boris.lema »
I'm having trouble with midi config files not showing in resolume .
It started with some XML files not showing but now nothing is showing. They are still in the Shortcuts > MIDI folder so i dont know what to do about that.
Anyone with a fix?
EDIT: Resolume Arena 7.13.1
Online
Re: Resolume not finding MIDI XML files
As discussed via email, the presets are probably created from the factory effects, and copied over, so they probably have the same UniqueID.
If Resolume sees presets with the same ID, only the first one will be loaded.
