Rekordbox video output (Syphon)
jvdatahan
Post by jvdatahan »
Hello ! I'm using the rekordbox 6 and i tried arena 6 and arena 7 but the rekordbox output still not working.
I want to use the Rekordbox Video output to resolume arena.
I got the "rekordbox - output" in Syphon Server (Sources) when i drag it in the tab, no video.
What should i do?
Re: Rekordbox video output (Syphon)
Are both apps running on the same GPU?
jvdatahan
Post by jvdatahan »
Zoltán wrote: Wed Oct 05, 2022 14:27 Are both apps running on the same GPU?
yes both app, running in 1 same laptop
Ok, But are they both using your dedicated video card, or is one of them running on the integrated. In latter case, they wouldn't be able to share the textures.
knappy
Post by knappy »
Just an observation...
The screenshot is Windows. Syphon is Mac (if I'm not mistaken)
I use a Mac and Rekordbox with Resolume and it works fine.
I think you need to use Spout on Windows.
djFLIGHTplan
Post by djFLIGHTplan »
Anyone in the Denver-area available and knowledgable to tutor me to get up to speed on using MacBook Pro-Rekordbox-Syphon-Resolume? If not local, happy to work remotely with someone as well. Happy to pay for your time. -dfFLIGHTplan
