Alley: fps for .png not working
movebandit
Post by movebandit »
Hello Forum,
it seems, that, when working with png sequences in alley, the framerate can only be changed file by file in the view tab. Select all files and changing doesn´t work. Now i have to recompress hundreds of png-sequences and its nearly impossible to change the framerate for every file manually..... any workarounds ? Fixes ? I´d love to stay with alley and not change to media encoder....
Greets
Maze
Re: Alley: fps for .png not working
Indeed it looks like setting the frame rate is only effective on the last selected sequence from a multi selection.
The default frame rate is 30. loading the clips to Resolume into a group and changing the group speed would allow you to change the playback rate.
